President
Better bump radius bending
Ensure you get the right bend every time
- By Steve Benson
- June 15, 2017
Editor’s Note: In his new book, Bending Basics, published by the Fabricators & Manufacturers Association (FMA), Steve Benson explains many key concepts for getting the most out of your bending equipment. The chapter on bump radius bending, excerpted here, explains how to calculate the best approach for your large-radius bend without employing special tooling.
There is a way that a large-radius bend can be performed on the press brake. It is by bumping the radius to the required angle and radius.
It is of particular value for the production of prototypes or when special tools are unavailable. In order to produce a bump radius there are some new terms that need to be explained.
The first term is the arc length, the length as measured along the inside surface of the radius (Figure 1). There are many different ways this length can be calculated. One of the easiest is:
Arc length = 2 pi R (the degree of angle/360)
Remember that 2 pi R is the circumference for a whole circle, 360 degrees. This formula reduces this number by the percentage of the arc angle. The number of times that a bend must be made to achieve the desired workpiece varies greatly depending on the desired results.
It comes down to time or cosmetics. The greater the number of steps, the smoother the outside of the radius will be (Figure 2).
Assuming that a smooth outside radius is desired, we begin by dividing the bend angle by two. If the bend is 90 degrees, the number of individual bends will equal 45 degrees. This makes the angle of each bend about 2 degrees, regardless of the final bend angle. The distance between each individual bend is found by simply dividing the arc length by the number of steps in the bends.
Die Width Selection (Bump Radius)
This die selection process differs from (standard die selection) because we will not be penetrating the die space to any great depth, only about 2 degrees per bend.
This means that we can use a slightly smaller die width than normally would be used. The optimum die width we would normally compute would be much too large.
The optimum die width for a bump radius bend is equal to two times the radius pitch (Figure 3). This smaller die opening allows the workpiece to lie flat across the top of the die set, instead of having one side of the part resting on a flat, and the other resting on the radius.
If a large die is used, you will never be sure that you consistently made contact with the backgauge. Consequently, each step could be in a different location, causing the final radius and angle to vary greatly from end to end. Except for some special occasions, the optimum die width for a bump radius bend would be expressed as:
Die width = Radius pitch x 2
Punch Radius
The required radius of the punch is, to some extent, irrelevant. However, it is best to use a punch radius that is not in the sharp bend realm, i.e., use a punch nose radius less than 63 per cent of the material thickness. The reason for not using a sharp radius punch is simple: a sharp bend punch radius will leave a more distinct bend line in the workpiece. This, in turn, will make for a rougher outer surface.
Depth of Penetration
The amount of penetration into the die space has a direct relationship to the die width selected. If you were to select your die width as described above, the depth of penetration would be about 2 degrees for a smooth outer surface. This will not be much deeper than the pinch point. Still, watch your tonnage loads. The pinch point is defined as the point where the punch nose is firmly holding the sheet material.
A depth of penetration’s starting point for the test bend can be expressed as:
Approximate depth of penetration = [(Die width / 2) + Mt – 0.02]
Process
Making the process easy requires you to be extremely precise, both in angle and flange dimension. Take the time to ensure the bend angle is consistent down the entire length of the part. Set up the tooling and check the angle by producing an angle somewhere between 60 and 80 degrees – anything but 90 degrees. This ensures an air form. Once accomplished, the press brake is ready to be set to 2 degrees, and air form.
Next, make sure that there is zero taper in the backgauges. Now you are ready to program the part.
The starting location will equal the leg (edge to tangent) of the workpiece added to the length of the arc. This will be your starting point as shown in Figure 4. It also shows how the workpiece is pushed out toward the operator as the forming process occurs.
Steve Benson is a member and former chair of the Precision Sheet Metal Technology Council of the Fabricators & Manufacturers Association International®. He is the president of ASMA LLC, 503-399-7514, www.theartofpressbrake.com.About the Author
Steve Benson
T&H Lemont expands sales team
TRUMPF to launch Flex Cell Bending Automation at FABTECH Canada
Helical coil inserts for soft metals withstand temps up to 800 degrees F
MME Langely
- April 10, 2024
- Langely, BC Canada
- April 16 - 17, 2024
- Cleveland, OH
